Hi:
I'm setting up Beosystem 1, Beovision 4-50, DVD-1, Beosound 9000, Beolab 1, Beolab 2, BeoLab 6000, Beolab 7-2 with a Scientific Atlanta Explorer 8300HDC set-top HD digital video recorder. I would like specific detailed advise on cabling these devices together.
I am thinking the DVD-1 should be connected as follows:
DVD-1 <to> DVD Input System1
Digital Output - RCA Phono <to> COAX - RCA Phono Orange
Audio Left <to> LEFT - RCA Phono White Back
Audio Right <to> RIGHT - RCA Phono Red Back
Data Mini Jack <to> CTRL Mini Jack Back
YC -AV S-Video Cable <to> S-VIDEO Back
CVBS <to> VIDEO - RCA Phono Yellow Back
I am thinking the Scientific Atlanta Explorer 8300HDC should be connected as follows:
Scientific-Atlanta Explorer 8300HDC Rev6.3 to STB Input System1
Video Out RCA Phono Yellow - Out 2 <to> Video - RCA Phono Yellow Back
Digital Audio Out RCA Phono Black Out 1 <to> COAX - RCA Phono Orange Back
CRTL - Mini Jack Back <to> CRTL - Mini Jack Back
Left - RCA Phono White Phono Audio Out 1 <to> LEFT - RCA Phono White Back
Right RCA Phono Red Phono Audio Out 1 <to> RIGHT - RCA Phono Red Back
Video Y/V - RCA Phono Green - Out 1 <to> Y/G - RCA Phono Green Top Panel System1
Pr - RCA Phono Red - Out 1 <to> Pr/R - RCA Phono Red Top Panel System1
Pb - RCA Phono Blue - Out 1 <to> Pb/B - RCA Phono Blue Top Panel System1
Beovision 4-50 Plasma Control Cable DB9 <to> USB2 to DATA System1 USB2 Jack Back
BeoSystem 9000 Beo Master Link RG Connector <to> System1 Masterlink Top Panel
BeoSystem 9000 DIN <to> Apple Airport Audio Out Mini Jack
Beo Eye <to> System1 IR Receiver Mini Jack Top Panel System1
RGB 5 BNC Connector Cable <to> System1 PROJ OUT DB15 Top Panel
Are the connects correct and are there any special configuration settings/configurations/software-code releases for the Beosystem 1 or Beo 4 remote? Does the S-A Explorer 8300HDC require any specific set-up/config ie 1040i only?
Thank you in advance,
Al
