beocool:I believe the Beosound 6 is based on the same hardware as the Samsung mentioned here. Difference is that B&O is supposed to have developed an algorithm that enhances the sound. Samsung uses its own algorithm. I am not completely sure, so can anyone confirm or correct?
This is correct - It has been tweaked by B&O to improve the standard MP3 player level of performance.
I've heard it, and it sounds stunning. Made my ipod shuffle sound broken ( both via A8's)
It comes supplied with A8 earphones, a nifty leather carrier, and will be c£350 - £375 in the UK, so in effect the actual player is c£250.
Due in shops in the next 5 - 10 days.
Form an orderly queue
Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
