Hello to all,
Beosystem 2300
Build 1991
Type no: 2616   S/W 1.1
Serial no: 09432647
I just got this system by a friend. It was not used for some time because of being not working anymore.
I figured out how to connect the wires. Mains to one speaker to the other speaker and then to the system.  5-pins Din from system to each speaker.
There is no remote control (anymore).
I understand this is a system with amplifiers build into the speakers (alike Philips had many years ago)
When I connect to main power, all functions seems to work, but:
There is NO SOUND out of the SPEAKERS!!
There is only one green led light in the left speaker, no led light in the right speaker.
On standby this one green led turns red.
Switching for standby to radio, or cd, or aux I can hear the relais ‘clicking’ in the left speaker and the led changes from red to green and vice versa.
Nothing clicks in the right speaker and no led light at all.
Cd-load is working, the windows opens smoothly, tuner is working, cd player is working fine.
I tried headphones and this works, meaning, there is sound on left & right headphone.
All functions of volume, bass, tremble, balans etc… are working fine.
I checked the fuse in the right speaker and this is ok.
Please, can anyone with some experience on this model help me out.
What should I test, how can I found out what the problem is, step by step...
It would be nice to make this set working again.
Should I post this item in 'Vintage models'??
Kind Regards,
Pierre, Belgium.
