Hi
I don't think it's in the puc list i haven't seen it.
The oneremote will work just fine if your mediacenter has an scart input, The HDMI input you use is assigned to a scart input wish is used for analog stereo sound and video signal used for link TV's. with the oneremote it's also possible to control the media center from a link room.
Ask oneremote if the remote you have is compatible with there scart control
