Hi all,
It's been a while and I love the new place (well it's new to me)...
I have been on the fence and doing a lot of research on the control of non B & O devices from the Beo4, and obviously come up with the two choices: Lintronic, and IRTrans/iRED...
I don't have a PC and don't want to have to get one, borrow one, etc for Lintronic (mainly because I am the kind of person who likes to tweak and experiment, and think that it would be a colossal waste of money to buy one just for the sake of being able to program Lintronic macros)...
So, I have been leaning toward IRTrans/iRED... I am wondering if I am correct in my findings that I can indeed use the IRTrans Translator module connected to my Mac in my living room to control both the Mac as well as non-B & O devices in it's vicinity (by allowing the software to learn the remote codes) and having the IRTrans module "translate" the mapped Beo4 codes to their respective IR codes for the non B & O devices.
I know this is a tedious task, but I would like to employ a device (the mac) which I am familiar with and enjoy using.
So.. is this possible, and what would I need? I have been in touch with Michael at iRED, and the gentleman who makes IRTrans, and here's what I have come up with as the ingredient list, please tell me if it is accurate:
IRTrans Translator + iRED license
IRTrans Translator Power supply (to overcome the sleeping USB ptoblem)
External 6 way IR blasters (which will connect to the IRTrans Translator) and to 6 external devices
The question I have is if the IR emmiter on the IRTrans translator is powerful enough to send IR signals to the entire living room (it is a medium sized room with windows on only one side), if this is so, I won't have to get the IR blasters.
Thank you for your input.
-Sal
Love B&O, but no longer addicted.
