Latest post 08-23-2007 1:13 PM by The Stig - ver. 1.7. 4 replies.
Page 1 of 1 (5 items)
  • 08-22-2007 12:42 PM
    Beovision MX Issue
    Hello All - new member here!
    I have a rather old but still excellent B & O MX TV, and have just purchased a new Panasonic DVD recorder to replace the old VHS.
    I was able to work the old VHS machine using cannel 6 (we have only arial input) but cannot remember how this was set up, but on trying to set up the new recorder I can get nothing on the B & O AV but can get sound only using the V Tape.
    I have tried the new recorder on other TVs and it works perfectly both sound and vision, and I have tried two different scart leads and made sure they are properly fitted.
    I would be most grateful for your guidance.
    Thank you. Smile
  • 08-22-2007 12:49 PM In reply to
    Re: Beovision MX
    I think you just need to tune Channel 6 in to the signal from the DVD player
  • 08-22-2007 3:43 PM In reply to
    Re: Beovision MX Issue
    you cant use the AV button... use V.tape and make sure the S.vhs is set to off in the TV menu.
    The DVD recorder don't have a modulator so it's not possible to tune in on it, on channel 6
  • 08-22-2007 4:14 PM In reply to
    The Stig!!!!
    Brilliant!  Many thanks.  Just what was needed.  Well done.
    Keith C
  • 08-23-2007 1:13 PM In reply to
    your welcome Wink
    and welcome to beoworld Smile
