Please help!
 I have 4 LC2s and cannot disable the on/off function on any of them. I must be doing something wrong but I can't understand what.
I follow the following procedure as stated in the instruction booklet via my Beo4:-
Press LIGHT then LIST to display SETUP. Press 0, the LIST to display STORE. Press GO, Then 1.
But it doesn't work!
I've tried the above procedure with the lights on and off, but it makes no difference.
As I live in Spain and powercuts are not uncommon, it means that if one has occured whilst I am out, when I return all the lights are on.
Any advice much appreciated.
