Hi
Is it possible that my IR eye on my beosound is turned off? I have just bought a Marantz RC5200 remote control. I have downloaded a couple of different CCF files for the beosound 9000 but nothing seems to work. I read another jolly complex thread about conecting a beosound to a beosomething and got lost!! But it talked about turning off the IR eye. I bought my 9000 second hand and wonder if the eye is turned off so wont work with my remote.
If it is, how do I turn it back on without a Beo4????
Thank you
Pete
