1st March February 2012
Latest post 01-18-2012 2:53 PM by baileyr. 20 replies.
01-17-2012 12:56 PM
baileyr
- Joined on 01-17-2012
- Posts 8
HI all
I have a pair of penta 3 speakers and an ouverture. last night i turned the ouverture off, both speakers auto turned off, LED's went red but 1 of the displays on a speaker froze and stayed on. The only way i could get it to turn off was to unplug the speaker, but now the display on that speaker doesnt work at all.
I havent moved anything, all audio/ video switchs are set right, ive swopped the displays and boards with the good speaker and they work, i was just wandering if anyone has a clue why the display should stay on after the ouverture was turned off, maybe a relay?? if so where should i look??
many thanks for any help
rob
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
I've seen that happening on my MK3's many times. I just don't mind it so much that I would actually service them or something.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Bentleyman
- Joined on 12-29-2008
- Rochdale
- Posts 367
bayerische:I just don't mind it so much that I would actually service them or something.
What....?
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
bayerische
- Helsinki, Finland
- Posts 3,593
Bentleyman:
What....?
The problem of the display being left on, is a small problem. So small that I don't see the need to have them serviced. (Or the Beocenter, they are connected to.)
-Andreas
Bentleyman
- Rochdale
- Posts 367
Ok, I thought that's what you meant.
So, what happens with the display when the unit is turned back on again? Does it resume normal functioning ok? And does the display remain on indefinately until the unit is turned back on? i.e. days, weeks, even months?
I dont have this issue thankfully, but am just curious.
Regards,
Michael
BS 7000, BS 5500
bayerische
- Helsinki, Finland
- Posts 3,593
Bentleyman:
Regards,
In my case, it's on a set I haven't used for years, but yes. As you say it stays on until the speaker is either unplugged from mains, or you put on the system again and it's back to normal functioning operation. Tunring it off again, might also turn of the display. Sometimes a mains disconnect is needed.
-Andreas
bayerische
- Helsinki, Finland
- Posts 3,593
Bentleyman:
Regards,
-Andreas
bsantini
- Joined on 08-31-2008
- Seaford, NY
- Posts 162
Unplug everything from the mains for "a minute or so." Then, plug in the Overture first, then the speakers. Should be ok.
B
Bentleyman
- Rochdale
- Posts 367
Rob,
Is everything else with the speaker working normally? E.g. is the sound normal coming from the speaker? Is the speaker going to standby as it should? Is the red/green indicator light working correctly?
Perhaps there could be a slight loose connection with the display itself if everything else works as normal. Could try taking the cover off and just having a play about...
I've never heard of a display actually breaking down but I guess they could do, in which case a replacement display would be in order...
I'm not technical enough to know myself, but hopefully some on here does.
Regards,
Michael
BS 7000, BS 5500
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
In Pentas, the displays work completely independently from the
amplifier part (they share the same mains transformer, but really
nothing else). The displays are also powered on (technically, not visibly) all the time while the
speaker is plugged into mains. There's a separate 40 mA mains fuse, but
that circuit also powers the standby part of the amp - if the speaker
itself turns on and works, there's nothing wrong with that.
Now either
- the display doesn't receive power - the fault can be in a
transformer winding (unlikely) or in the wiring & connectors between
the amp & display. You should have 10 VAC coming up between pins 2
& 3.
- the display doesn't receive data (which could also cause it to not
turn off, when it doesn't see the STANDBY command) - same wiring
problem as above, or a problem in your speaker cables, or in the
audio/video mode switch in the speaker
- the display itself is faulty - you don't replace it, you get it repaired (they don't make these any more you know...)
- Penta 3 seems to have another fuse on the display module itself (can't see why it would give up & blow, though).
I'm quite sceptical of something getting loose or shorted inside the
speaker just by chance if you don't even move them around. One likely problem
is a short / open in the Powerlink cabling, disabling the data connection. Pinched by a chair leg recently
perhaps?
The display module has a couple of capacitors which I hear are sometimes bad. More likely in an old pair than a 3.
baileyr
- Posts 8
if i ignor the display not working everything works exactly as it should. the display (2 x cicuit boards) are good as i swaped them with the good speaker and it works as it should.
I sort of ruled out the cable as i used a brand new one after the fault happend, but then even new ones can be faulty, so i will swop with the known good one.
But if this doesnt work i'm gonna just strip them both down and start swopping parts.
I'll post an update if and when i find the problem part.
thanks to all for the info/help
baileyr
- Posts 8
that was looking promising as the cables had been squashed abit so i rewired the damaged parts.
The problem is definatly somewhere in the base as i swoped it over with the good one. Ive put a link in to make doubley sure its not the fuses, swopped the front circuit board (with the swithes) still nothing. Checked the audio/video switch has continuity and works.
on the good speaker im getting 6v (i think) between brown and blue(??) at the plug that conects to the rear circuit board for the display but on the faulty one im getting 0.1v, so next guess would be a resistor maybe?
tournedos
- Finland
- Posts 5,808
baileyr:on the good speaker im getting 6v (i think) between brown and blue(??) at the plug that conects to the rear circuit board for the display but on the faulty one im getting 0.1v, so next guess would be a resistor maybe?
I have no idea of the colours of the wiring, but the DIN connectors are numbered as they always are (possibly molded in plastic beside the pins as well). The supply to the display modules comes up in pins 2 & 3 (there was an error in my above post). And it's AC, not DC.
And there are actually two separate mains transformers, the smaller one supplies the standby circuit (which is working for you) and the display from another winding. If you have isolated the fault in one of the amplifier modules, it really can't be much else than the wiring / connectors to the display, or a faulty standby transformer.
tournedos
- Finland
- Posts 5,808
OK, so the display apparently works and has power... I believe it's time to try and find where the data gets lost then.
This is unfortunately a bit more involved (and difficult without the service manual) as there are some active electronics in between. What you might do is check the solderings of the Powerlink socket in the bottom of the amp - I presume you're using that since you have an Ouverture.
baileyr
- Posts 8
Now this is bloody wierd
the first thing i swoped with the good speaker were the displays and they both definatly worked with the good speaker.
I swoped the base's over and only the good speakers base powerd BOTH displays. So after some rewiring and continuity checks i put everything back together but still no display in the 1 speaker.
ive now swoped the displays again and the display out of the good speaker now works on the faulty one but not the other way round.
By swoping the pcb's ive now got it down to the rear circuit board from the display (must have damaged something with all the taking apart)
Page 1 of 1 (21 items)
