 stotty1111:
 stotty1111:
I agree, am using an Active with an IR eye as a slave , masterlinked to an Ouverture, with the MCl2p power linked to the active, works well with a pair of RL6000's
Tony
Tony's solution will give you exactly what you need/want!
Main room:       BLB 4000 - sound controlled via BeoSound Ouverture
Dining room:    Passive Speakers - sound controlled by a BeoLink Active (MasterLink!) and
                        powered by the already existing MCL2P power-amp.
                        (MCL2P connected to the BL-Aktive using existing PL-Cable)
Shopping List: 1 BeoLink (ML) Active (including IR-Sensor & Sensor-Cable)
                        1 ML-Cable from Ouverture to BeoLink Active
Alternative:     1 BeoLink Passive (including IR-Sensor & Sensor-Cable)
                         1 ML-Cable from Ouverture to BeoLink Passive
                         MCL2P is not needed - sell it!
Forget MCL solutions if you already have a ML Audio Master (your Ouverture) !!
It's outdated, more complicated and offers very limited possibilities to adjust the sound independently.
As long as your MCL2P and not a ML/MCL converter is used as a MCL Driver the main room can't be
muted independently.
Some MCL limitations:
Xtra Speaker Kit - type 2047            - independent ON/OFF in Link-Room
                                                         - volume and sound adjustments delivered by master unit
Xtra Aktive Speaker Kit - type 202x  - independent ON/OFF in Link-Room
                                                         - different volume to a certain amount
                                                         -  sound adjustments delivered by master unit
                                                         !! for active speakers - will need a 2nd MCL2P to power passive speakers  !!
Xtra TV -  type 2031-2040                 - independent ON/OFF in Link-Room
                                                          - different volume to a larger amount
                                                          -  independent sound adjustments (Bass/Treble/Balance) possible
                                                          !! will need a TV  in the Link-Room !!
