Latest post 12-22-2011 7:25 PM by CJM1. 4 replies.
Page 1 of 1 (5 items)
  • 12-22-2011 2:26 PM
    • kazzav
    • Not Ranked
    • Joined on 12-22-2011
    • Posts 4
    Beosound 8
    hi everyone, i was wondering if you could help me. i am looking to buy a pair of beosound 8 speakers but as you know they are fairly pricey and if i were to buy them from america it would be considerably cheaper but im not sure if they would work in britian were i live as theyre may be a voltage difference or something else i am not aware of? thanks
    Smile
    Filed under:
  • 12-22-2011 2:52 PM In reply to
    Re: Beosound 8
    Yes they will work fine over here dude. I think that u will have to throw the box away etc therwise you will get taxed on it!  Maybe some of the other guys can advise   Seriously if you can get it for 999dollars then you are laughing - is that around £640???  Huge saving!!!
  • 12-22-2011 3:01 PM In reply to
    • kazzav
    • Not Ranked
    • Posts 4
    Re: Beosound 8
    thanks man and yes it is around the £640 mark and yes you have to factor in shipping and everything aswell but its still a bargain in my opinion! Smile
  • 12-22-2011 5:13 PM In reply to
    Re: Beosound 8
    Voltage is 100-240v and uses a standard figure 8 cable. Can be used anywhere in the world Yes -  thumbs up
    My B&O: 2009 Catalogue and Pricelist
  • 12-22-2011 7:25 PM In reply to
    • CJM1
    • Not Ranked
    • Joined on 09-01-2011
    • Posts 35
    Re: Beosound 8
    For a man like you i would recomend a Sony iPod dock. they certiantley could whip the quality of the BeoSound 8!!
    Stick out tongue
