1st March February 2012
Latest post 12-16-2011 8:20 AM by Kokomo. 9 replies.
12-23-2010 4:26 PM
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
UnityRemote, universal remote for iPhone, compatible with Bang and Olufsen
I have just discovered this new UnityRemote today. It is an app plus a device that turns your iPhone into a universal remote.
The device is connected to the iPhone via bluetooth, so you do not need a dongle connected to your phone. You just place the device somewhere in the room and it transforms the bluetooth signal into IR signals to control any IR device.
I do not have the device, but the App is available for free on the iPhone, and Bang&Olufsen is available in the list of IR codes! Hurray!
Raeuber
- Joined on 12-02-2007
- Posts 986
Re: UnityRemote, universal remote for iPhone, compatible with Bang and Olufsen
Hi Phil,
thank you for the info!
I have downloaded the free app on my IPod touch, but it crashes in the demo mode every few minutes. I think it´s because of IOS 4.2.1 on my IPod, which is not officially supported yet.
I also don´t believe it will work fine with the whole B&O equipment, so I will not purchase the device.
Although it will only work as one way remote, the idea is brilliant, espacially the customers can program the app by themselves. B&O should also offer such a device for use with the Beolink app (without Masterlink Gateway), but I don´t think they will do so. If B&O would bring out such a device for their Beolink app with bluetooth for one-way remote or with WiFi for two-way remote, nobody would need a Beo 6 anymore!
I wish you a happy christmas!
Räuber
Kokomo
- Joined on 08-21-2007
- Spain
- Posts 618
Thanks Phil, great idea and the first of many such apps in the future I think.
Agree with Rauber that B&O should embrace this concept and launch one themselves that doesn't need the MLG to function.
pehre
- Posts 41
I can not find any confirmation, that the Gear4 unity remote is working with Bang&Olufson equipment. Do you have any confirmation?
PhilLondon
- London
- Posts 2,545
Download the free app and run the demo mode. I remember seeing B&O références.
pehre
- Posts 41
O have ordered it and its works with my Ouverture. Ilittle difficult to install.
joehomm
- Joined on 12-29-2010
- Posts 76
Hi there,
is there any new information 'bout interacting with B&O? B&O should now open up! Every new TV, DVD or Bluray device can be fully controlled with the iPhone.
Best regards Joe
joehomm
- Posts 76
Yes, that's true. The application is now about 1 year or even more in the App-Store, but unfortunatelly you have to own a Master Link Gateway, which costs about 2000,- Euros!!
And there is much trouble with the iPhone handling and controlling.
B&O has released a "Workaround solution" for this problem:
"Bang&Olufsen recommend to use the Beo4, Beo5 or Beo6" ... thats the answer when you ask B&O for help, AFTER you spend that much money in a solution! Crazy, isnt it?
Best regards joe
Kokomo
- Spain
- Posts 618
Padrig:
Great, but as has been pointed out, the MLG is still required. One step forward, two steps back!
Page 1 of 1 (10 items)
