Just taken delivery of a BV7-40 3D and it was set up by my dealer.
Connected to the tv are a Sky 1TB HB box, Humax 1TB Freeview box.
I am using a Atlona HDMI 4 by 1 switcher and to get 5.1 sound from the
Sky box l have used a QED Reference Digital Audio cable connected to the SPDIF socket at the back of the tv.
When the dealer tried to plug this lead in it would not fit because the shell of the male plug is bulky and the socket is partly recessed into the plastic back panel with a very tight clearance around the SPDIF sockets.
To get around this problem the dealer has used a cheap and cheerful cable to join my expensive cable to the tv he has also used this method to connect my Beosound 5 as well.
To say l am not happy would be a understatement why would l spend over £20,000 on this system and to have to use cheap audio cables in my set up to make the final connections what a bad design by B&O.
Any ideas what to do next would you insist the dealer took off the back of the tv and in large the hole around the SPDIF sockets?
