Latest post 11-29-2011 10:03 AM by Alex. 3 replies.
Page 1 of 1 (4 items)
  • 11-27-2011 4:48 PM
    • o0l0o
    • Not Ranked
    • Joined on 11-27-2011
    • Posts 2
    Power info for BeoVision 6-26
    Hi All, i have below, 220v-Power info for BeoVision 6-26, does anyone know
    what I should get to convert into 110v, I need specifications for New York-USA usage,
    Thanks for any info.
    rOn
    Filed under:
  • 11-27-2011 5:29 PM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-16-2007
    • New York, NY
    • Posts 176
    Re: Power info for BeoVision 6-26
    Hi Ron!  You can bring it to any of the stores in the city and we can have the voltage converted for you.  Not sure where you're located but my shop is on 21st street and Broadway.
    Sadly this model was never designed to work in the US so don't expect the STB-C or tv tuner(s) to work.  Hope this helps!
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
  • 11-27-2011 6:10 PM In reply to
    • o0l0o
    • Not Ranked
    • Posts 2
    Thanks, much appreciated, what is STB? Do you mean im not able to use it a a TV, w/TMC or verizon fios? thanks.
  • 11-29-2011 10:03 AM In reply to
    • Alex
    • New York, NY
    • Posts 176
    o0l0o:
    Well you'll be able to connect your sources to it (with some adapters), but you will not be able to control them using the Beo4/5/6.  I should be at the store today if you would like a little bit more concise an explanation.  +1(212)388-9792
