1st March February 2012
Latest post 11-17-2011 7:36 AM by stefan. 5 replies.
11-16-2011 8:17 PM
Chris
- Joined on 05-09-2010
- Last of the Summer Wine Country, Yorkshire, UK
- Posts 195
Does anyone know the function of the IRtrans Translator? When would it be used? It is B+O 455mhz compatible.
http://www.irtrans.de/en/shop/translator.php
Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Search the forum.... you will find all the information you need.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Chris: Does anyone know the function of the IRtrans Translator? When would it be used? It is B+O 455mhz compatible
The IRtrans is compatible with the B&O 455 Khz (not Mega Hz) carrier frequency and several members use this product.
stefan
- 200 miles from Struer
- Posts 1,733
The IRtrans can receive and transmit Beo codes. I tested this product years ago, but I switched to the Lintronic box, because it`s more flexible.
Can be contoled and control IR (incl. Beo commands), switches, X10, RS232...It can even be triggered by datalink from Beo Scart sockets to control 3rd-party devices like stb, BD players, mediaplayers.It can also contol Beo commands in a MCL linksystem via an MCL2A (AV)
You can program macros and use the new LIGHT and CONTROL functions of the nwéw Beo4 navi.
My son is controling all his stuff - Samsung TV, Digiality stb, xbox, BM3300, BG3300 with Beo4 via a Lintronic box using macros.
My cinema setup is controled by a Lintronic box via the cinema socket on my BV7-40. My blinds are controled by a relay box 108 also made by Lintronic.
And they have an online database for IR codes.
Stefan
Chris
- Posts 195
Do you know the cost of the linktronics box ? Thanks
stefan
- Posts 1,733
See:
http://lintronic.dk/TT455-RT-238.htm
Stefan
Page 1 of 1 (6 items)
