I've got two Beocenter 2500's with door and CD playback issues.
The doors on both systems would not open and close originally. I read the thread on this issue and replaced the motor control board on one, and fixed the other one. The door belts were replaced on both units. I also took apart the motor and lubricated it on both units.
Now the door will open half way on one, and stop. The microprocessor seems to be sending the correct signal to open the door, and the limit switch seems to fire when the door starts to open. Any ideas?
On the other unit, the doors do not respond to a hand wave in front of the unit now. Any ideas?
Finally, one of these units has also started to develop a problem with the CD section. CD's would not be recognized any longer when a CD is inserted. I adjusted the appropriate pot described in the service manual. This seemed to clear up the problem until the unit was briefly unplugged. Now, it is exhibiting the same problem recognizing CD's again. I haven't tried to readjust the pot. Is there something else going on here?
Any input would be greatly appreciated! Thanks.
