Hi:
I'm wondering if those familiar with the TX2 would mind answering a few questions for me.
1) Moving the tone arm left and right; is it rather slow? especially compared to a Beogram 8000?
2) When you move the tone arm to the extreme right (ie depressing the right key until the tonearm can not go further) does it it start clicking as it tries to push further across to the right?
3) Does the above also happen in the 45 rpm mode? Ie you play a 45 record so the arm cues to the center, but when you force it to the right by pressing the right key it starts clicking as if something is obstructing its path?
I'm trying to determine if my TX2 is functioning properly.
Thanks,
Derek
