Hello, I just bought a used one has beomedia brnacher on my BeoVision Avant RF. I also have a BeoSound 9000 MKI. I managed to connect the image and sound of the BeoVision 1 BEO before but it is not possible to navigate or operate the beomédia with a BEO 4 REMOTE CONTROL.I did not connect the IR sensor. Someone please advice
From memory you need to connect the ir sensor to BeoMedia1 when using an Avant (or any other TV that doesn't recognise the "PC" command).
Opman
