Latest post 09-27-2011 3:16 AM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 09-26-2011 1:24 AM
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Config files for my setup
    Hi all,
    does anyone have the codes for the following setup?
    Twin tuner sat receiver Cubecafe 420s
    Benq w600 beamer
    Cheers,
    Kevin
  • 09-27-2011 3:16 AM In reply to
    Re: Config files for my setup
    Hello Kevin,
    I am assuming from your comment that you want a Beo5/6 XML file to control these two products ?
    I do not have the IR codes for these products, but if you have the original remote controls, the codes can be captured.
    Regards Keith....
