shaywhelan:
I tried pressing RECORD - STOP - STOP on my Beo4 remote but the TV still thinks it is recording!
I also tried to add "LOCK" and "UNLOCK" to my Beo4 but these irems did not apear to be available on my BEO4 remote.
Any other ideas?
Shay
Ok, strange. Did you try a reset? Is it possible to set the BV to standby ? (red stdby light).
What is connected to your BVs AV1 port? If anything is connected to AV1 with a scart plug, disconnect the plug and try again.
If this works connect your external device to AV2 port.
And try to press RECORD - STOP - STOP in V.MEM (V.TAPE) mode. Beo4 RECORD button usually responds just to V.MEM (V.TAPE).
Stefan
