        1st March February 2012
	    Latest post 07-27-2011 3:47 AM by  bayerische. 16 replies.
								        07-24-2011 11:12 AM
									        bayerische
								                - Joined on 12-11-2007
								                - Helsinki, Finland
								                - Posts 3,593
										    Beolab 8000 & BL 5000 installation
										    Hi guys,
Just wanted to share some of my new speakers at my restaurant Albatros.
Enjoy.
First BL8000;
The metal bases has been removed, and the speakers are bolted through the wooden shelf. (using the original bolt that was fastened to the metal base)
Second minty BL5000.
I had custom brackets made, so that they are fastened to the wooden pillars instead of the wall.
Thanks for looking!
									    -Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
									        tournedos
								                - Joined on 12-08-2007
								                - Finland
								                - Posts 5,808
										    Re: Beolab 8000 & BL 5000 installation
										    Brilliant   The BL5000 bracket is clever!
If you ever feel a need to improve something, I would route the cabling of the BL5000s up behind the speakers, then to the side and down along the pillars - that way you could move the white cable channels away from the stone wall.
									        Søren Mexico
								                - Joined on 09-13-2007
								                - Mexico city
								                - Posts 1,621
										      tournedos:
Agree with Mika, but a perfect place for the 5000s, and I love the 8000s way up there, just beautiful, congratulations.
									    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
									        beocool
								                - Joined on 10-17-2007
								                - the Netherlands
								                - Posts 5,514
										    Fantastic Andreas.   I like the way you mounted the 8000's to the shelf with the original bolt.   Also clever use of the pillars instead of the wall for mounting the 5000's.
									        hemenex
								                - Joined on 04-23-2007
								                - Posts 375
										      tournedos:I would route the cabling of the BL5000s up behind the speakers, then to the side and down along the pillars
Yep, and use black cables; then as soon as they reach the left resp. right white pole mount the cable channels to the white pillar instead; they will be more hidden...
   Gunther
									        Daniel
								                - Joined on 04-17-2007
								                - Svinarp, Sweden
								                - Posts 1,284
										    Wonderful, a restaurant I would place a lot of tip in, no matter how the food tastes!
									        bayerische
								                - Helsinki, Finland
								                - Posts 3,593
										      Evan:
Andreas, that is impressive! Those 8000s look great on top of the bar, but those 5000s look absolutely stunning!!!! WOW.
Thank you Evan!
									    -Andreas
									        bayerische
								                - Helsinki, Finland
								                - Posts 3,593
										    Well you are right about the wire covers, I'll change them at some point.
									    -Andreas
									        Large48
								                - Joined on 06-24-2008
								                - London
								                - Posts 455
										    Aren't the BL5000 the wrong way round?
Same issue I have with mine, shouldn't the 'speaker' side of the unit be in the middle and not on the outside?
									    Train Hard - Run Fast - Hit to Kill!!!
									        joeyboygolf
								                - Joined on 04-16-2007
								                - Ely, Cambridgeshire, UK
								                - Posts 3,252
										      Large48:
Why??
You can hang whichever way you like. Just change the L - R switch on the back.
									        Large48
								                - London
								                - Posts 455
										    Isn't there meant to be a better 'spread' of the sound due to the speakers being further away from the side walls, so less 'bounce' back?
all non-teckie speak there! LOL
									        beocool
								                - the Netherlands
								                - Posts 5,514
										      Daniel:
I can assure you the food is great too!
									        joeyboygolf
								                - Posts 3,252
										    Who told you that !!!!!
If B&O thought that, they would not have put the  switches on the back?
The installation instructions say that you can mount them whichever way suits your fancy!
									        bayerische
								                - Helsinki, Finland
								                - Posts 3,593
										      joeyboygolf:
Exactly, I hung them this way (after testing both ways) because it looked more balanced with the painting.
									    -Andreas
									        Leslie
								                - Joined on 05-07-2009
								                - Netherlands
								                - Posts 2,201
										      joeyboygolf:
Why??
Switch the amp units as well and voila, a complete mixed Beolab 5000  like a real Mondriaan
									    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
									        bayerische
								                - Helsinki, Finland
								                - Posts 3,593
										      Leslie:
  joeyboygolf:
Why??
That's going too far!
									    -Andreas
        Page 1 of 1 (17 items)
