        1st March February 2012
	    Latest post 07-04-2011 11:08 PM by  Checkler. 30 replies.
									        Razlaw
								                - Joined on 04-24-2007
								                - Illinois
								                - Posts 1,770
										    I do not have this info on my Beosound. I have software update set to automatic and have tried manually checking for software update.
Unless I am not looking in the right place for it.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
									        linder
								                - Joined on 04-16-2007
								                - Posts 653
										    No new software on my BS5 also!
									    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    Stan, what software version is showing on your Beosound 5?
									        Stan
								                - Joined on 04-17-2007
								                - Posts 593
										    Most peculiar!
The BS5 software version displayed when I go into "maintenance mode" is 6.03.00.2455.  Mine is also set up for automatic updates, and I did nothing to make get this update.  I would not have even noticed if all of my N.Radio favorites had not disappeared (this happened last time there was a major updates).  I had been listening via linkroom all week, and had not even looked at my BS5.  When my N.Radio stations disappeared, I went to see what was the problem, and the "readme" screen, describing all of the new features, was displaying on the BS5.
It seems like I may have accidentally received this too early?
Stan
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    I will check my version when I get home.
									        pf85
								                - Joined on 04-21-2007
								                - Posts 145
										    No Update yet.
Mine shows version 6.02.00.1902
Looking forward to the update. I still don't understand that B&O is not advising its BM5/BS5 customer base upfront of any changes. With the registration they have our email addresses....
									        mbee
								                - Joined on 04-18-2007
								                - Paris, France
								                - Posts 1,133
										    Nothing special here : B&O seems to do like other manufacturers : they push a pre-release (let's say Golden Master) of the software to a reduced number of customers, and then look at the error logs they get from those customers to see if everything is fine. Then they push the update to everybody.
Looking at the french forum, it seems that Jeano has big problems with this update : maybe for this timr it's a chance if you didn't got this specific update.
									        Stan
								                - Posts 593
										    Here's the information about the update that my BS5 has told me.
Stan
									        Stan
								                - Posts 593
										      mbee:
This makes sense.  So far, aside from the loss of my favorites, this update seems fine for me.
Stan
									        linder
								                - Posts 653
										    Thanks mbee and Stan for this information.  It looks like there are going to be a lot of new possibilities for the Beosound 5.  I had noticed significantly increased network activity on the Beomaster 5 at around 2 am central time and checked to see if any changes had been made.  It appeared nothing had changed and I ignored it.  I hope the error free software is loaded soon.  I might even buy a Beo6....maybe!
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    I am feeling really dumb. How do I find the software version?
Thanks!
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    Thanks! I have 6.02.00.1902
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    I contacted my dealer to order a Beo 6. Dealer tells me that the 2 way is not yet available and I should wait to order a Beo 6.
									        f5434964
								                - Joined on 07-21-2010
								                - Posts 198
										    To get a 2 way experience I would need a device to send and receive signals from eg an IOS device; any ideas how this problem is/would be solved? Do I have to buy a W-LAN stick - and try to get it run on windows (!!!!!)? I don't thinks that there is already something installed within the BM5 waiting only to be activated by software-update...
regards, elmar
									        beojeff
								                - Joined on 11-29-2007
								                - Posts 543
										      f5434964:
regards, elmar
You just need to have a wireless network in your home and have your BM5 connected to the network either via a wireless network adapter or wired directly into your LAN via ethernet cable.
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    Hopefully the updated software will be forthcoming soon for everybody, not just a few as the case seems to be now.
									        beojeff
								                - Posts 543
										      TWG:
As I understand correctly:
  The Beosound 5 finally get's AUX IN functionality via USB-Audiointerface? That's great news!
  Could you use any USB-Audiointerface?
Wouldn't it be great if we could have a USB to DIN connector and have the BeoSound 5 send datalink commands to a BeoGram or BeoCord? I know that's backwards-thinking on my part and there would be a very small market for that. Still, the thought of the possibility is so nice!
									        beolion
								                - Joined on 10-20-2009
								                - Posts 245
										    I think it is great to hear that B&O open up for 3rd parties, like Apple. And I hope that B&O will keep open for, I believe this will increase the value of a BS5 system if it easy can interoperate with other systems.
And since BM5 is "just" a PC, then why not?
I do not have any Apple products (yet, I have to admit), but a LOT of people do have some kind of Apple, and looking at the BS8 sales, there must be a market potential here for B&O.
									    There is something about B&O.....
									        BeoMegaMan
								                - Joined on 11-25-2007
								                - Posts 66
										    B&O accidentally put the update on the server which sends it out. Some of you may have gotten the update some of you may haven't. If you haven't it is for the better as the new update was purely a test version not meant for final use and has problems all over the place. If you have gotten it you will need to restore your BM5 then update to the current version via B&O. This is the only work around for right now. But at least you know what to expect when the update comes out :)
									    BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
									        linder
								                - Posts 653
										      BeoMegaMan:
Thanks for the information.  You are correct.  Even though this was an accident, we now have a greater understanding of what to expect.  However this does highlights B&O's management problem with this product which is lack of communication.  For those Beosound 5 owners who have the misfortune of not being aware of Beoworld, one can only wonder how they knew what the problem was or how to resolved the problem.
