Latest post 06-29-2011 12:20 PM by Erik-nl. 1 replies.
Page 1 of 1 (2 items)
  • 06-27-2011 2:25 PM
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    Beosystem 2 and SP/DIF
    Anyone have any idea how to use the SP/DIF input on a Beosystem 2? The manual says just plug it into SP/DIF 1, but it also insists on having the SCART feed the audio as well (at least in the manuals it does unless the source is VGA). In fact removing the SCART cuts the audio completely, suggesting to me that the SP/DIF connection just isn't used.
    I'm keen to use this so I can remove the SCART completely from the system!
  • 06-29-2011 12:20 PM In reply to
    Re: Beosystem 2 and SP/DIF
    I think that input is use a kind of sync on the cvbs signal.
    I remeber to have read that also line audio on scart only works if there is a video sync
