You need to carefully lift out the uppermost lips of the hinge plastic parts out from
their grooves, away from the metal lid (towards you), just two millimeters or so and
lift the lid straight upwards at the same time.
An ultra-thin watchmakers screwdriver is good for this.
Like this:
