All MX tv's equipped with the 4 pin stand socket will work with the same stand motor and there are only two mounting plates, one for 21"TV's and one for the 26"TV's.
It should be noted that the stand socket on the MX4200 and the MX8000 is different. It has 5 pins and requires the motor with a matching 5 pin lead.
