Dillen:(fit the platter, check for parallelism against the
alu surfaces) and allow the glue to set.
I may be wrong, but the alu surface is not part of the swinging chassis, isn't it better to check against the "bottom" surface of the swinging chassis, if the chassis is wrong adjusted the flange will be even so ??
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
