Hi
I have intergrated my Beosound 8000s into my A/V system using the Line Level input, but I've got a curious problem.
When watching a movie at low volume, the speakers switch into and out of standby randomly. This also happens when the AV amp is switched off, and also with the RCA lead removed. It's very erratic. The left speaker might do it, then the right, then not at all for hours, then starts up again. So far they've not done this together.
They behaved perfectly when hooked up to the Beolab 2 and Beosound 3000 with the control link cables.
It's really irritating and hopefully there is a fix. Anyone else seen this problem?
