Latest post 05-11-2011 4:17 PM by Douglas . 3 replies.
Page 1 of 1 (4 items)
  • 02-24-2008 4:20 PM
    Shadow mark on screen
    Hi everyone. I have a Beovision 6-22. After the TV has been on for about an hour, a dark 'shadow' or mark appears on the picture over to the left hand of the screen. Does anyone have an idea what is causing this?
    Filed under:
  • 02-24-2008 8:13 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Shadow mark on screen
    Is it under warranty? If so, back to the dealer it goes!
    If it had been a CRT, i'd have said it's too near to a speaker - but LCD?? I'm sure someone on here can help advise what the fault may be. Welcome to BeoWorld !!
    Lee
    Smile
  • 02-25-2008 6:56 AM In reply to
    Thank you!
    Well it does look exactly like the shadow you would get on a CRT near a speaker...excpet its not CRT and not near a speaker!!!  Its not under warranty sadly. It only appears after about an hour, so I wondered if it was some sort of strange software problem, rather than a problem with the backlight.
    I think I know this is bad, I was just hoping someone had information otherwise!
    P
  • 05-11-2011 4:17 PM In reply to
    Hi, did you find out what it was? I only ask as I also have the problem on a BV6-26 on the right
    Regards Douglas C
