1st March February 2012
Latest post 05-02-2011 4:04 AM by scottyltd. 18 replies.
04-27-2011 5:39 PM
Lanny
- Joined on 01-07-2008
- Posts 17
I just bought Beosound 8. It has great sound, especially for the higher bit rate music. I do have a couple of observations though:
1) iPad 2 wobbles quite badly - it is too thin for the docking mechanism. I write to Customer Service and the referred me back to my dealer but he has the same problem and at least another customer complained. I don't believe this is iPad tested/ready.
2) The B&O app in the AppStore is, well, amateur. I did buy it for the 12 Euro since I have a great iPad tuner app and I can also stream stations from my mac iTunes.
The major disappointment, though, is that with the unstable docking situation I would not want to wall-mount - the iPad 2 would fall out of the vertical position in no time.
Tomaz
- Joined on 11-07-2007
- Germany
- Posts 74
Re: Beosound 8 and iPad 2
1) the new ipad is at the bottom actually very thin. just a small line... A) the BS8 needs a suction knob or B) Airplay inside
Lanny
- Posts 17
Yeah, well, but it is still B&O. When I put in my iPhone, I get AirPlay and stability.
Ehlerz
- Joined on 04-17-2007
- DK
- Posts 510
Taking the B&O product development cycle in considerartion, the BS8 is probably testet with an Ipod 1. generation back in the days. :-)
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
Karel Uyttendaele
- Joined on 05-19-2007
- Aalst, Belgium
- Posts 682
I think no one except Apple knew what the dimentions of the iPad2 were going to be before launch... So B&O bashing for the BS8 not being 100% iPad2 compatible is a bit harsh... let's just hope that some kind of adapter will surface.
The race for quality has no finish line- so technically, it's more like a death march.
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
A major drawback of being the Monkey rather than the Organ Grinder!
Apple can, at will, render your new product all but obselete overnight (not quite in this case but it should serve as a warning not to depend on Apple entirely for your product lineup).
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Karel Uyttendaele:I think no one except Apple knew what the dimentions of the iPad2 were going to be before launch... So B&O bashing for the BS8 not being 100% iPad2 compatible is a bit harsh... let's just hope that some kind of adapter will surface.
Precisely what annoys me about all the cries on how B&O or whoever should "embrace" Apple - while at the same time Apple can do anything they want without any advance information to others or promise of continuity. And everybody thinks it's fine
Heribert
- Joined on 08-06-2009
- Austria
- Posts 592
My dealer told me today that B&O already works on an AirPlay version of the BS8
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
Lanny
- Posts 17
I quote from technical support response
We can inform you that iPad 2 is tested for use with BeoSound 8. Furthermore we can inform you that we are working on a solution to make an iPad fit more stable on BeoSound 8.
This is in direct response to the accusation of B&O bashing
Karel Uyttendaele
- Aalst, Belgium
- Posts 682
Lanny.. it would have been "nice" if this was included in your original posting... :-)
Lanny
- Posts 17
It would have been if I had it. It just arrived.
malcolm welborn
- lanzarote canary islands
- Posts 180
A week after researchers discovered that Apple's iPhone and iPad devices were tracking and storing customer locations as they moved around geographically, the company finally issued an official response, disavowing some of the claims while admitting to software bugs. But he big question now is: What took Apple so long to explain itself? more
so lets bash apple for a change
Karel Uyttendaele
- Aalst, Belgium
- Posts 682
Don't understand the fuzz about the whole "tracing" stuff.. It's been known since IOS4 was released. It's even been discussed in a couple of books. Granted.... positioning was recorded IN your iPhone, nothing was transmitted to Apple. Keep in mind that other smartphones do the same.
Also... whevenever you take money out of an ATM, make a cellphonecall... your ever move is being written in some database. Nothing new...
Now.. let's go back to B&O
Alex
- Joined on 04-16-2007
- Bath & Cardiff, UK
- Posts 2,990
malcolm welborn:
The iPhone remembers which WiFi networks it has discovered, and where it thought these networks were related in comparison to it's location according to GPRS in order to make the maps application more effective.
I've been using my iPhone 3GS since just after they came out and I haven't yet been hunted down
Weekly top artists:
malcolm welborn
- Posts 180
the problem is apple were storing the infoand was unencrypted, as against smartphones etc who encrypted it and did not store, so the report said.
the CEO for apple admitted the software bugs
Alex
- Posts 2,990
malcolm welborn:
Not even a problem as far as I'm aware - no personal data was stored.
All a load of hype over absolutely nothing (as per usual with the media).
Weekly top artists:
Lanny
- Posts 17
Not only not a problem, but those who follow security issues had known about it for months before it became a feast for mainstream media. And no special free software was needed, either. If you want to look at the structure and content of my data, go to http://iplaq.com/iphone ...
Page 1 of 1 (19 items)
