Mine is a BV8-32, not sure what my SW level is, I have tried looking for it on the service menu, but I think I have the wrong set of secret key strokes
FORMAT > GO just triggers format 1 by default (at least that is the text that flashes briefly on the screen)
The Foxtel is plugged into AV1 and set to V.AUX and always defaults to FORMAT 1 which just may be me using an incomplete SCART cable
AV2 is DVD which is associated to the HDMI to the Apple TV 2G ... and also has its SCART port plugged to a cheap DVD for optional usage
AV3 swaps the HDMI with AV2 and is used with the MacMini in PC mode
AV4 is another SCART to a B&O VHS recorder we never use
Only having the one HDMI is a small pain, I am trying to decide how best to redeploy the MacMini !!!
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
