You can - however there are two problems!
1. The tape lead has
a 7 pin DIN plug - you will need to unscrew these pins so that the plug
will fit the 5 pin DIN socket on the 1900.
2. You cannot record as the 1900 uses DIN standard and the 3500 uses LINE standard. You can play tapes though.
