thanks lee, the cd's are "the mix" by kraftwerk, "powerslave" by iron maiden and one other i couldnt mention for fear of a slating from members. its only ever been these three and no others, i had bang and olufsen of willen (mk) reset the doors (my fault) and i asked them to check the laser and all was fine (last year).
ive had the unit and cd's since 2004/05 about the same time i purchased the beolab 8000's from you. which are stillgoing strong. thanks for that. could it just be conflicting data on discs?? but i must add if i press randomly a track number button on the unit i can sometimes get them to work.
btw its klaus naomi the secret disc.... yeah exactly....
(formerly nokinnikon from the old site)
