Latest post 03-20-2011 6:00 AM by 6walkerstep. 0 replies.
Page 1 of 1 (1 items)
  • 03-20-2011 6:00 AM
    Who to change the modulator on/off AVANT 32
    I have being using Avant 32  as master in my linksystem. Have been working very well.
    No I have installet a BV7 And I have change it to be the master. But as I understand it is not possibly to use both with modulator   The problem is that I have only 2 line in AVANT menu so I can´t switch it off.
    1=TV LIST
    2=SETUP
    Is there any way of reset  and start all over again.
    Also what should the BO4 be programmed with   LINK ????
    It is only the Video signal that is missing. Radio, CD .. works ok.
    My set up is  BV7 (master) AVANT32 , BL2000, BS4500, BL3500, BM1, MX4000
    BV7 have STB decoder Motorola VIP1903  Works ok.
    Need info who to set all up.
