1st March February 2012
Latest post 02-23-2011 9:12 PM by BeoTom. 34 replies.
04-15-2010 7:23 AM
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
Re: Beocenter 9000 questions
The sad fact is that although many Beocenter 9000's look like new, they all have a problem area. The CD servo board will undoubtedly fail sooner rather than later due to capacitor problems and the CD clamping mechanism will fail due to disintegration of a tiny unobtainable piece of plastic!
So, if it wasn't for the CD they would be a good buy!!!
I have never tried it but a Beolink converter type 1611 should enable the Beocenter 9000 to communicate with a ML system.
Personally, I would not pay more than £100 as, if all else fails,you can flog the 2 glass panels and get your money back!!
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Had my old Beocenter 9000 conncted through a Beolink converter to my BV3-32. One limitation I found was that you cannot set the Beocenter to Option 0. Or any other Option for that matter. So you got double commands when using the remote. Not sure if there was a later S.W. revision to cure this.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Large48
- Joined on 06-24-2008
- London
- Posts 455
I have one connected to an Avant via the convertor box with speakers connected to the Avant and it all plays fine through the ML link.
Train Hard - Run Fast - Hit to Kill!!!
TWG
- Joined on 04-17-2007
- Germany
- Posts 950
The Beocenter 9000s asking price is 600 Euro.
I'm a little confused about that CD servo board and plastic piece... is the tiny little plastic piece s.th. I could easily fix with spare parts from another CD player?
Now I'm unsure...
Peter
- Joined on 02-12-2007
- Posts 9,572
Seems expensive to me - I would get the 9500.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
TWG:
Now I'm unsure...
500 Euro's too much IMO.
The small plastic part is what holds the CD in place & is no longer available. I think B&O only used it in this model so no other CD player in the range has it. The CD servo board is also only used in this model & failures have been documented many times on the forum.
I agree with Peter - you can get a 9500 for the same money (probably even less) which is a much better buy.
Chris.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
I agree with Graham, Peter and Chris though most faults to these are actually easily fixed. The CD clamp may be an exception but the CD servo board can usually be repaired fairly easy and cheap. I normally try to steer clear of advicing regarding value but the price you mention do sound a little higher than what most of these seem to go for. Having said that, it's a beautiful system and it's worth what you are ready to pay.
The Beocenter 9500 is slightly newer than the 9000 but within recent years it too has started to show CD reader faults (more than 95% of them fixable). Stuck sliding doors and slipping belts, the cassette belts falling off, cracked solder joints at the voltage regulators, bad muting relay, lose glass panels. As with most things, there are many standard issues but all fixable.
I once started looking in to the Beocenter 9000 CD clamp but never cam up with a good fix.
Playstation, Discman and laptop CDrom drive clamps of different types have been tried without much success. Maybe a reproduction of this part would be the way to go.
joeyboygolf
- Posts 3,252
Dillen:
The 9500 exhibits most of the same faults as the 9000 as most of the components mentioned are common to all models in the range.
The exception is the CD clamping mechanism which is peculiar to the 9000. If the OP buys a 9000 and the plastic widget breaks up on the day after, he is left with a very pretty but large and expensive cassette radio.
There is no prospect, in the short to medium term, of an alternative being found or produced and it is unfair to state otherwise.
In the last 12 months I have scrapped at least 6 perfectly good 9000's for want of a 10p plastic widget. We have to face facts, the 9000 is as good as useless if you cannot play CD's.
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
There has to be a result for these...
If S(t)onk is following this thread... I believe he made mention of considering working up a fix???
I would be happy to give it a go... I just don't have a 9000... or more importantly, the part in question!
I'd bet a cold beer that this can be solved.
OP: 600 in any currency is too strong (except USD, of course! ).
joeyboygolf
- Posts 3,252
burantek:
Several people have made mention of reproducing the part in question. Nothing as yet!!
Why not??? Because the volume is so small that it would end up so expensive that nobody will pay!
The part in question, unless you can find a new one, is almost impossible to remove in one piece and you end up with yet another cassette radio!
Of course, any problem can be solved if you thow enough money at it but with the majority of threads on the forum championing how little that the poster has paid for certain items or complaining that B&O in general is too expensive, I hardly think that is going to happen!!!
Stonk
- Marlow, Bucks, UK
- Posts 1,688
I would love to see the infamous part - even if it's broken in two pieces.
There are ways to reproduce plastic parts without the need to resort to expensive injection moulding. If this part is intricate then it probably can't be done but if it's a fairly simple item then it might be worth a go. Nothing for financial gain but purely something to do while she watches
Desperate Housewives/Sox in the City/Lost etc.
If anyone has the broken part and can send it to me to study I'd appreciate it. You'd get it back plus one of the results if successful.
If you think nobody cares, try missing a couple of payments.
TWG
- Germany
- Posts 950
I'm glad to have this forum and you people!
Thank you for your answers and help - and congratulations to myself that I asked you BEFORE I buy it
What should be a good price for a Beocenter 9000 or should I go with another piece of equpiment? In my personal opinion the Beocenter 9000 looks better because of the matt finish (I don't like the polished surface on the 9500).
burantek
- SE USA
- Posts 6,214
Oh Graham... It is not the mountain, but the climb!
Sonk... I agree!
T.W.G... You may always find someone willing to swap panels with you?
Stonk
- Marlow, Bucks, UK
- Posts 1,688
I'm sure the 9300 had the matt finish (often upgraded to the mirror panels) though I may be wrong. The 9300 is the newer and last of this wonderful Beocenters and prices in the UK range from £350 to £700 from a second life dealer with warranty. Beo4Life (Joeyboygolf) is currently selling one but doubt if they ship abroad.
joeyboygolf
- Posts 3,252
Stonk:
Most 9300's had the polished panels until the last 2 years or so of production when the design changed to matt panels and no white stripe round the perimeter. Also of significance is the CD mechanism which changed about that time to the more modern CDM12 linear laser as used in modern Ouverture derivatives.
A significant proportion of our business is "abroad" and Germany is no problem. I currently have a matt finish 9300 for sale.
Medogsfat
- Posts 4,045
Stonk:
Me too! when it comes to bodging rectifying & or reproducing otherwise obsolete parts it is the sort of thing myself & Stonk relish
Chris.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Medogsfat:
Stonk:
Chris.
Me too Don't actually have the tools, but I strongly suspect it could be turned out of nylon, or something.
But the plastic piece is only part of the problem. I'm afraid that when it breaks, approximately 97.4% of people lose the spring that belongs to it... and was there still some more tiny bits that belong to the construction?
Stonk
- Marlow, Bucks, UK
- Posts 1,688
tournedos:approximately 97.4% of people lose the spring
That's very precisely approximate
Dillen
- Posts 5,008
Graham wrote:
"Of course, any problem can be solved if you thow enough money at it but with the majority of threads on the forum championing how little that the poster has paid for certain items or complaining that B&O in general is too expensive, I hardly think that is going to happen!!!"
You have a point here.
The same was the case with the Beogram 6006/8000 tangential decks with the common tachodisc problem. The Beograms sold for next to nothing as a repair was deemed impossible. I had new discs made. It was a costly process but I've noticed that the going rate for those Beograms went up, even for a defective one. Actually some owners paid more for the tachodisc than they did for the deck itself but a fully working and serviced tangential Beogram is worth considerably more than a broken one and with that in mind, it is a justified investment.
If the CD clamp could be reproduced (and I'm sure it can), it will not be a 5p part and the same pattern will show, I'm sure. Even if some functions on the Beocenter 9000 can still be used with the CD player out of order (the Beogram with a bad tachodisc was useless), the Beocenter 9000 will probably then see a price rise as well since it is a very nice and classic piece with lots of fans. But of course, that would spoil the bargains people make and like to tell the world about.
TWG
- Germany
- Posts 950
if the plastic part is not too complicated I could imagine, that any talented modelbuilder could "clone" this part with resin or other synthetic materials!?Does anybody have a photo of the thing we're talking about?
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
Graham,
How can the capacitor issues on the CD section be overcome? I've just been given a BC9000 and the CD player indeed has some issues, it takes the CD, starts spinning and stops right after to re-open the sliding door...
Don't know whether this is due to the well-known cap. issue or to something else, though..
Reunion Island is greeting you!
BenSA
- Durban, South Africa
- Posts 808
joeyboygolf:
Dillen:
Is it possible to purchase a 9000 that you are going to scrap?
