Hi.
I just got myself some white P45 speakers which are black. Confused? I am. I know they're white because it can be seen on the inside when the grill is removed and there is white under a small chip on the outside. So perhaps someone painted them black. Well I don't think so as the finish is very even with just the right sheen. So my question to the wise here is has B&O ever been known to do custom finishes.
Also, three of the grill cover posts are broken. Does anyone know of a supply or will I have to buy some P30s or other for spares.
They sound great by the way and I will stabilize the bass drivers right after I've done the same with my S45s.
Thanks for any insight you can give.
Trevor.
