Hello all, I haven't posted for a while, as not as clue up as most on here, but always enjoy a good read to built my b&o and AV knowledge and will take this chance to say what an excellent forum this is,
Im currently running an early beo 4 65 (around 2006 at a guess, it came with the house so not 100 percent) with a beosystem 2, beo9s, beo 8000s and beo2 and have other beovisions and music players in other rooms connected by masterlink,
The panel was upgraded to what i think was 1080i, and after a nitemare with connections for about 12 months (as the upgrade menu setting for dvi port was taking the best connection for the non hd channels until resolved) we were finnally left with an excellent set up, where as, I use my ps3 for movies using the optical for sound and direct hd connection and to turn the hd on I have to flick to pc on the beo 4 remote which I am very happy with, picture and sound are 100 percent to me.
My B and O dealer, which I have a very good relationship with, have now suggested I try the beosystem 3 out on loan from them on a 3 week demo, I accepted, when they arrived to plumb in the demo unit they could not get the tv to work as the set up menu for the beosystem 3 is displayed in 1080p which my beovision4 does not have so they have took the sysytem 3 away for tweeting and will return soon,
My questions are, do I need a beosystem 3, will I notice any difference on normal sky (non hd) or on the HD picture my ps3 produces through my direct connection to the panel, is it worth 5k to upgrade, is there any resale value in a beosystem2, will i get teething problems as last time I changed something problems continued for months and months.
From what i can see is, my gain will be I can have skyHD, which didnt work on the direct link as I am now, ( which i found very strange as the ps3 works fine apart from a bit of white noise on the screen on start up for about 2 minutes which clears completly (the skyhd had very bad constant white noise on the screen and had to be rejected, sky may have not connected it correctly though)
also at the moment I only get 5.1 sound through the ps3, so sometimes we do not get sound on menu pages of movies discs as it is not always played in 5.1 and I dont get any sound on the Iplayer on the ps3 as im guessing that isnt 5.1 either.
I would like to have the beosystem3 if I am going to see improvements and ease of use of the tv for the wife,
Thanks again for reading my post, and it would be great to get as many comments as possible and will update here when the demo finnally gets connected and works I hope.
thanks in advance,
