Latest post 01-22-2011 2:44 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 01-21-2011 12:22 PM
    Size comparison between reel to reel decks?
    I need to find out if the Beocord 1500 DeLuxe cabinet is the same size as the Beocord 2000 DeLuxe K.  The 1500 DeLuxe has turned up close to me and I have been looking for  the 2000 to fit in my console Beomaster 1200 RG.
    Guy
  • 01-21-2011 1:48 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Size comparison between reel to reel decks?
    I have had them both and I'm quite sure their cabinets are the same size.
  • 01-21-2011 5:24 PM In reply to
    Smile Thanks Martin...
    ...then I guess I'll go and check out this reel to reel.  He does say that the reels turn slowly.  Are belts still available for this model?
    Guy
  • 01-22-2011 2:44 AM In reply to
    • Dillen
    • Posts 5,008
    I don't have them. - At least not yet.
    Slow running could also be a result of dried lubrication.
    You will have to look inside.
