Hi Beoworlders,
I'm currently using my Beomaster 6500 to drive a pair of Adam A7 active speakers from the PowerLink outputs. Due to the gain-staging, I have to wind the volume up to ~70 on the amp to get any decent level (works well for me, I can't really turn the volume up as I'm in a flat). Should I be worried that there's nothing hanging off the BM6500's amplifier outputs with the sort of levels I'm turning it up to? It's effectively running an infinite impedance...
Season's greetings,
Alex
