Hi, I have a Beovision LX2802 (model 3807) that I can't seem to get the sound to work.  I was given it many years ago, and it worked then.  Unfortunately in the meantime I have lost the remote, so I can only change channels by pressing the button under the front panel.
Any suggestions?  If I had a remote, could I change the sound?  I think originally it had a Beolink 1000.
The sound does work through the headphones..
Thanks in advance!
