I am still trying to add a remote volume control to the Beolab 5000 System.
If I connect this device, does anyone know if the quality will suffer?
It almost looks like it is to be connected in the same way as an equalizer via the tape in out ?
http://www.audioplex.com/RCLL1%20revised.pdf
I plan to add a Sonos system that will connect to the aux input but I would still like to use the Tuner and Record player and still have the capability of remote volume control.
