Hello,
My brother has just purhasesd a LX5500 from ebay to replace the same model that finaly gave up the ghost. It came with the rather nice heavy die-cast remote.
However no matter what I do i cannot get the TV to accept an input on scart 1. Scart 2 works fine with the matching VHS recorder and from my investigation it looks as if pressing SHIFT + TV should give access to scart 2 and SHIFT + TEXT allows some form of scart setup.
However SHIFT + ANY BUTTON does absolutlty nothing.
Any advice would be gratefully received.
Thanks htiek
