Latest post 12-10-2010 10:31 AM by Spiros. 11 replies.
Page 1 of 1 (12 items)
  • 11-30-2010 6:26 AM
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Datalink (7pin DIN to 7 pin DIN) cables
    Has anyone got any spare they'd like to sell me?
    Cheers
    Nigel
  • 11-30-2010 7:05 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Datalink (7pin DIN to 7 pin DIN) cables
    Hi Nigel, I think I got one. No need to pay anything but the shipping costs. It should be around 2m. Please contact me by email. Best regards Spiros
    Best regards
    Spiros
  • 12-03-2010 4:05 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Any answer?!?!
    Best regards
    Spiros
  • 12-04-2010 1:23 PM In reply to
    • h1npw
    • Posts 776
    Hi Spiros
    Apologies in not getting back to you sooner. I've sent you an email. Many thanks for your generousity
    Cheers
    Nigel
  • 12-04-2010 1:40 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Really happy to be able to help a fellow Beoworlder!!
    Best regards
    Spiros
  • 12-05-2010 3:25 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Great to see Beoworlders helping eachother ! Yes -  thumbs up
    Please note that Beogram turntable datalink cables are different from Beocord tapedeck cables.
    The Beocord cable is two-way (record and playback).
    The Beogram cable is one-way (only playback) but has double shielding.
    The cables are not interchangeable though you can play back from a Beocord using a
    Beogram cable (but you cannot record) and you will get a serious hum if using a Beocord
    cable with a Beogram.
  • 12-05-2010 6:57 AM In reply to
    • h1npw
    • Posts 776
    Hi Martin
    Presumably you can use either cable with a CD50?
    Cheers
    Nigel
  • 12-05-2010 7:30 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Martin, I think it should be possible but CD50 should already have it's own 7pin cable? Best regards Spiros
    Best regards
    Spiros
  • 12-05-2010 2:29 PM In reply to
    • Dillen
    • Posts 5,008
    The CD50 does not have a captured (permanent) cable.
    A Beocord cable will work fine, no need for double shielding.
  • 12-06-2010 5:26 AM In reply to
    • h1npw
    • Posts 776
    Many thanks to you both
    Cheers
    Nigel
  • 12-10-2010 9:55 AM In reply to
    • h1npw
    • Posts 776
    Hi Spiros
    The cable arrived today! Many thanks again for your generosity.
    Cheers
    Nigel
  • 12-10-2010 10:31 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Nigel, Happy to be able to help a fellow Beoworld member. Best regards Spiros
    Best regards
    Spiros
