Using Config Tool 3.87 you just change from "No navigation button" to "Navigation button Mode 1". You will find it in section "Choose products". Click on your videomaster (BV7 ?) and the settings menu will display: Stand - Modules - Sources - Navigation buttons...
Stefan
