Hi Beoworld,
once again i find myself at the mercy of you experts in the WWW. A newly discovered problem is as follows. I have my BS9000 connected via Masterlink to my BV3/32 "think the most basic setup possible" just the BV3, Masterlink lead and BS9000 thats it no extra speakers, "as yet" The sound is really wonderful for the first 4 hrs then "SHUTDOWN" both items go to standby. A little annoying, it will start ok as soon as i press CD on the remote, i cant recolect this happening when i was listening to the BS9000 on headphones "just that no masterlink connections". Any help much apprechiated, BTW BV3 is set on opt 2 and BS9000 on default opt 0. one other thing, when the system is on and i alter the sound there is no visual cue on the CD clamper to indicate the volume, (In the NO Masterlink config there is a visual cue), and of course the BV3 goes to no picture mode as it should so i have no visual just the green led on BV3 blinking to confirm.
Regards Maurice.
