Hi there
I remember on the old forum Dillen (Martin) once advertised his capacitor upgrade (refurbish) kit for the RL range of speakers. Apparently exchanging the old capacitors will improve the sound. As I have just moved and my RL6000 are not installed on the walls yet, I thought I might as well put some new capacitors and check the drives while they are not "in the air".
BUT: Where is Dillen (Martin)? It would be too great a loss if he is not around any more...
Best regards
 Chr
									    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
