Latest post 10-11-2010 1:55 PM by elephant. 1 replies.
Page 1 of 1 (2 items)
  • 10-10-2010 10:25 PM
    Media center
    Hey all you b&o fans
    I searched the fourum but dident really find an theard with good information. Maby you guys can help me out. Ok i now builded an windows home server and thought about using it with my BeoVision 7. The guy in the stor said i can run windows media server and there i can chouse from dvds i have ripped or musik i am storing... But i have no idea how to do this (witch kabels, hardware, software...)
    It would be nice if someone can help me!!!!!!
    Beovision 7, BeoCenter 2, BeoSound 8, Beosound 5, 2x BeoLab 9, BeoLab 3500, 2x BeoLab 8002, 2x Beolab 4, 2x Beolab 5, 4x BeoCom 1, 2x Beo4, Beo6, 2x A8 headphones, Audi with b&o sound system
  • 10-11-2010 1:55 PM In reply to
    Re: Media center
    tere is a strong Apple Mac following here that uses a fellow member's (Philippe) software called LINKPLAYER to achieve the control & integration; ripping is typically done using HANDBREAK
    Beoworld searches for both those will reveal a wealth of information for you or take a look here
    http://www.conversation-it.co.uk/LinkPlayer/Linkplayer.html
    I no longer track WIndows so I can't answer for that environment, other than perhaps you look at how inexpensive an old Apple TV would be to acquire; the challenge with LINKPLAYER would be that in addition to a second-hand Apple MacMini or MacBook you would also ideally need to buy the BEOPORT black box
    Some members are now investing in and recommending TVIX black boxes ... and some B&O stores have bought them to demonstrate that as a Media Centre approach
    http://www.tvix.co.kr/eng/
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
