a7d7:
Thanks for your help. I just tried the turntable with a friends Beomaster 5500 and it sounds great! I'm going to look for a Beomaster 5500 to use with the turntable.
I also bought a Master Contol 5500 with the turntable but I can't get that to work consitently with the borrowed Beomaster 5500. I'd like to find a manual for it.
Thanks again for the quick responses!
If you have a good working BM 6500, you will only need a preamp, I use my BG 2404 with my Beosound 3000 and a JEC TL 754 preamp, no problems, and that one you can get "over here".
But if you want to get a BM 5000, you can ship your 6500 down to me in Mexico
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
