I suspect I already know the answer. Does the moulded plastic back come off or do I access the crossovers by removing the bass drivers?
I've got a rather nice pair of these in teak which I've just reconditioned the cabinets of (previous owner mistook them for coffe tables) & would like to replace the cap's in the crossovers.
For anyone interested in my method of refurbing the cabinets :-
Sand down with 400 grit sand paper to remove the old laquer & any surface blemishes. Then apply button (French) polish in 3 coats. Lightly sand with 800 grit paper after the first coat, then with steel wool after coats 2 & 3 to give a super flat surface. Finally apply beeswax & rub.
I'll post a finished photo tomorrow when I have decent light.
Chris.
