Latest post 09-28-2010 10:24 AM by Gianfranco . 5 replies.
Page 1 of 1 (6 items)
  • 09-21-2010 10:43 AM
    Beogram 4004 problem
    Hello friends,
    I have a BG 4004 that change the speed himself, but no from 33 to 45, when it arrive at the middle of the disc the speed go down and after the 3/4 of disc turn up. What I can check ? Thank you
  • 09-21-2010 2:56 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: Beogram 4004 problem
    As knowone else has asked yet I will have a go...
    Not sure if this makes sense.. is this when the arm is moving to engage a 7" 45 record that you get this problem?
    Olly.
  • 09-23-2010 7:18 AM In reply to
    Hello, no, I use only 33 record and around the middle the speed go down and after some turns came back normally. I check the arm and it seems good.
    If I go with << to clean the disk , the speed not change.
  • 09-23-2010 2:11 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Something catching between platter and transport?
    Olly.
  • 09-27-2010 4:15 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Check all the capacitors on the Control PCB for high ESR.
    Most will need replacing.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 09-28-2010 10:24 AM In reply to
    Step1:
    Hi,  it no catch.
    I will try to check the capacitors. Thank you
