Thanks Martin,
Once I'd done a search within "beogram", i did find a similar thread.
Apart from the usual suspects (solder, caps, tacho) I think this may be the nylon bearing insert problem, as the guy clearly hasn't removed the platter before moving it. and there was a record on there in his picture, so this probably added to the problem during its transport. (he apparently moved it across the country, and after that its never worked since).
Diagnosis without inspection though, so could be something different. I think I'm gonna risk it though, and make him an offer.
Although, the needle thats with it is a black MMC 20 S ? I thought the CL, contact line cartridge was standard with this model - not the base model stylus!
Looks like I'll be on a stylus hunt as well!!
Another project to add to the mounting list!!
